esata drive not shown in windows.
Ok i have a Seagate freeagent pro 500g external HDD. Was running usb but new MB has esata so i wanted to give it a go. Well not so easy as i thought.
If esata drive is hooked to port when computer loads ,Bios sees the drive but wont get past the windows load screen.
Unpluged from port and windows loads fine. So i plug it in and windows makes the normal noise but nuthing shows up. Wait 7 mins a drive apears but will always cause page to stop responding.
Usb still works fine jus rather esata due to larg files
