How does adding more fans help?
  1. Posts : 15,026
    Windows 10 Home 64Bit
    my brother installed a new fan in my computer (it has 4 fans now)..and i noticed that one loud grinding sound that used to come when the pc was powering up is heard less after installing the new fan..(the DVD rom's sound)..
    so i want to know how adding more fans help the computer..and why is the sound so less now?
  2. Posts : 475
    Windows 7 Pro x64 -- PCLinuxOS KDE4 FullMonty 2011
    Possibly the fan that is on the way out does not have to work (spin) so fast. More air = less heat....to a degree.
  3. Posts : 15,026
    thanks for replying Doofus.
    the thing is, the DVD rom doesn't work the right way. like, i have to push a pin in that small hole and then it ejects the box. and before installing this new fan when i used to start up my computer,say after 8 or 9 hours there used to be this grinding sound from the cpu (in my guessing it was from the DVD rom, cause its spoilt) that sound is less now. what would a new fan have to do with lessening that sound? (or was it never the sound from the DVD ROM?)
  4. Posts : 475
    Fans possibly don't have anything to do with it. It's probably a warning to track it down & replace it. One day it might go POOF!
  5. Posts : 2,686
    You need to locate the source of the noise. It could be a fan going bad. It could be your CPU fan and with the additional fan the CPU is running cooler and its fan does not have to spin as fast. Just a guess, but I would try and locate the source of the noise.
    Jim
  6. Posts : 15,026
    Jim
    yup., my friend had told me that the DVD ROM has a problem and it makes this loud noise when starting up :)
    I will be getting a new one soon hopefully :)
