PC Fan Problem
Page 1 of 3 123 LastLast
  1. Posts : 3,168
    Windows 10 64bit
    PC Fan Problem
    This started like in December and i open up my case and see nothing wrong with my fans but i believe it might be the cpu fan not sure because at start up it whirls then after like 1-2min of being logged on it goes quiet. Should i worry about this? When i first bought it ,it did not do this was really queit. Could it be possibly because i OC my radeon card but it doesn't have a fan on it so don't think that could be causeing it because it doesn't over heat its at 38c? Temperatures don't go up its actually really cool only problem is that whirl sound bothers mefrom when it starts up. Would like some advice on this to what to check for and do.
  2. Posts : 12,012
    You can manually stop your case fans or graphics card fans for a second or two to see if the sound disappears in order to identify the source of the noise.
    If it isn't the CPU fan making the noise, I wouldn't worry about it as long as it still worked and the temperatures remained in line. If the noise bothers you, there are quiet fan replacements.
  3. Posts : 475
    Windows 7 Pro x64 -- PCLinuxOS KDE4 FullMonty 2011
    At startup a fan or two of mine sometimes make a great whirring noise then slowly quietens down. I just keep mindful of it & have the temperatures monitored just in case they fail.
    If they did the computer will automatically shut off with the heat.
    As long as the fans quieten down after startup it should be OK. At least you know they are working.
  4. Posts : 11,269
    Windows 7 Home Premium 64 Bit
    I've seen this on a number of PCs. It may be dust related, it may be related to the environment you are in, or it may be BIOS related. In some cases, cooler ambient (room) temperatures will result in the fan not having to start up as fast, and higher ambient (room) temperatures will result in the fan starting up faster. The reason it will die back down is likely due to a setting in the BIOS to run the fan quietly and only speed it up if the computer gets above a certain temperature. Once the sensors register that the temperature is low enough, the fan quiets down again (which is probably what you are experiencing after being logged in for some time).
    Things to check:
    1. Is room temperature higher than it was when the fan used to be quiet on startup?
    2. Is there dust in the machine (have you used a can of compressed air or low pressure compressor to blow it out recently since not all dust may be visible)?
    3. The BIOS version can also control fan speeds. Have you updated the BIOS since the fan was quiet on startup?
    4. Chipset drivers can also affect fan speeds for some boards. Have you changed chipset drivers before you noticed the change?
  5. Posts : 3,168
    Windows 10 64bit
    could it be that i have cool and quiet enabled in my bios and yes i'm updated to my latest bios provived by asus for my mobo. Does need a bit of cleaning i guess. Also can i get shocked trying to stop the fans. I've always been kind of hesitant at touching it from the inside when its on
  6. Posts : 11,269
    Yes, the cool and quiet feature is what I was saying that allows it to run quietly until it reaches a higher temperature, then it cools down to a lower temperature, and then the fan runs quiet again.
    Touching the fans will not shock you as they are plastic, but be careful not to touch any other components, and do not stop the fans too long as that would stop cooling and possibly damage components that overheat.
  7. Posts : 3,168
    Windows 10 64bit
    il'l try the method of stop each fan for a sec and see if the noise goes away once i arrive home and am not home atm, Il'l post again once i figure out which fan is causing problems or if it stays the same
  8. Posts : 3,168
    Windows 10 64bit
    Well i tested the fans it is the cpu fan that's being loud but like I have mentioned before it quiets down after 1 min when logged onto windows. It's just loud when booting and for 1 min when logged into windows. So I should be fine and not worry i'm guessing?Also my cpu is idle at 50c is that normal?
  9. Posts : 11,269
    50C is a little higher than mine (38C), but still within tolerances. Have you blown the dust out to see if it gets lower and the fan gets quieter?
  10. Posts : 3,168
    Windows 10 64bit
    i cleaned the whole pc today and clean the cpu fan its still loud at start up and it sits idle at 50c which worries me a bit since i game on this machine but i just turned it on and it's sitting at 49-50c
