Each command is run individually in command prompt followed by Enter. You will create 1 partition on the disk covering the whole disk.
You could create several partitions, but that will complicate matters. We can always delete that partition once the chkdsk is done and define a smaller partition leaving the rest unallocated.
The bootmgr message you probably got because you were trying to boot from that disk.
