StarTech 6 inch 4 Pin to 8 Pin EPS Power Adapter with LP4 - F/M
Page 2 of 2 FirstFirst 12
  1. Posts : 4,466
    Windows 10 Education 64 bit
    This reliable EPS adapter combines a P4 power supply connection with an LP4 power supply connection, into a single 8-pin EPS motherboard connector, allowing you to use a non-EPS power supply with a motherboard that requires an EPS power connection."
  2. Posts : 9,582
    Windows 8.1 Pro RTM x64
       #12
    My mistake, sorry.
    I've had a close look at the image, and the ATX12V plug supplies one half, whereas the molex plug supplies the other half.
  3. Posts : 4,466
    Dwarf said:
    My mistake, sorry.
    Hey, thats OK, I've used that smilly a couple of times my self.
    Thats what I've been trying to point out. I'm an Electronic Engineering Technologist by trade and have worked as an Electronic Technician since 1980. Part of my duties were the repair and maintenance of computers. Sometimes that can get me into trouble when I won't let things go that I think are wrong. To honest it is hard to be 100% certain just going by that picture and description. I had to look closely at it a couple of times to be sure in my head how I thought it would be connected. I've used similar cables and I know what voltages are on what pins so that makes it a little easier for me. Regardless of what I say though, its still up to the OP to read the instructions (one hopes there are some) and judge accordingly. It probably would work with only one plug used but those wires may overheat due to excess current. As you correctly pointed out though, it probably advisable to only use this as a temporary fix and get a better power supply with the correct cable on it.
  4. Posts : 617
    Windows 7 64Bit Ultimate Edition SP1
       #14
  5. Posts : 1,030
    Linux Mint / XP / Win7 Home, Pro, Ultimate / Win8.1 / Win10
       #15
    YTBOY83 said:
    I shall be purchasing the Corsair CMPSU-850TXV2UK Enthusiast Series TX850 V2 High Performance 850W Power Supply. Check out the video and link's below.
    Now that's a good idea!
    Regards,
    GEWB
  6. Posts : 26,870
    Windows 11 Pro
       #16
    Good choice. I have 2 Corsair HX models and am very happy with both. Neither has shown any sign of trouble.
  7. Posts : 4,466
       #17
    Like the others have said, sounds like a good choice. I wish I had one.
  8. Posts : 617
       #18
    Thank you for the help folk's. I connected both cables and have had no problem's.
  9. Posts : 26,870
    Windows 11 Pro
       #19
    That's great to hear. I'm glad you have it running the way you like it.
  10. Posts : 4,466
       #20
İ Designer Media Ltd
