Battery Replacement Toshiba OEM or Battery-Biz
  1. Posts : 8
    Windows 7 x64, Ubuntu 11.04, Ubuntu 10.10
    I have to replace the battery on a toshiba L355-S7915 laptop. Which battery is better? The Toshiba battery or the B-5040H from battery-biz. anyone use battery biz?
  2. Posts : 14
    Could you provide links?
    I think with batteries the big thing is Watt/Hours. (Don't quote me on that tho)
    You might be better off using the same battery as the one you had before, simply for the sake of reliability.
    It also will depend on what you use this laptop for.
  3. Posts : 8
    Laptop Battery for Toshiba Satellite P200 P205 PA3537 at TigerDirect.com <-the Battery-Biz
    Toshiba Primary 9-Cell Li-Ion Laptop Battery <-The Toshiba Brand
    I am more curious if it is safe to use a brand like battery biz or if its about the same as using the OEM brand. In the end its a $50 price diffrence.
  4. Posts : 564
    Windows 8 Pro
    I would go for OEM Toshiba battery but thats just me.I don't usually trust batteries for laptop from unknown manufacturers.
  5. Posts : 5,795
    The no-name batteries most often die rather quickly, putting you right back in the same boat. If it was me, I'd spend more and get the OEM battery, knowing I had the backing of the real OEM behind it.
  6. Posts : 564
    Windows 8 Pro
