How do I confirm that my CPU cooler speed is variable ?
Page 2 of 2 FirstFirst 12
  1. NRT
    Windows 7 Ultimate 64-bit SP1
    ickymay said:
    yes
    AddRAM said:
    Your BIOS will give you the best reading. There are also settings you can use to change the speed.
    ken9122 said:
    NRT said:
    NRT said:
    I stressed my CPU by opening a program... now the fan speed varies to 2385 to 2545 ... and CPU temp from 34 C to 39 C ... so my fan speed is variable... Am i right ?
    anybody plz confirm my previous question...
    Those temps are low so it's still on idle. need to get to above 50C or so to speed up the fan on most standard Bios settings.
    Ken
    Thank u all for replying.... :)
  2. Posts : 525
    windows 7 home premium 64 bit
       #12
    NRT said:
    ickymay said:
    yes
    Ken
    I'm currently encoding a movie. My CPU is running at 59C. CPU fan 1921 RPM. Case fan 1982. Ambient 42C
  3. NRT
    Thank u for the info Quickdraw2011... :)
  4. Posts : 53,367
    Windows 10 Home x64
       #14
    HWMonitor will list min and max CPU fan speed.
    A Guy
  5. Posts : 525
       #15
    No problemo!
  6. Posts : 525
       #16
    A Guy
    The utility Fanspeed shows min and max by hovering the curser over fans. I believe it's an older utility and not as detailed as HWMonitor.
  7. Posts : 4
    Windows 7 32 bit
       #17
    You can go to BIOS or dowload speedfan to monitor the fan speed of the cooler actually. Then you can play around with the setting to see if the fan is moving up and down.
  8. Posts : 525
       #18
    quickdraw2011 said:
    NRT said:
    ickymay said:
    yes
    Ken
    Forgot to mention, the rig I'm using to encode a movie is an old XP machine, with single core processor. Pentium 4 Prescott Core (P4). They run hot!
    Check out this article.
    Testing Thermal Throttling in Pentium 4 CPUs with Northwood and Prescott cores
