Problem Copying ISO Files Between Harddrives
Page 1 of 6 123 ... LastLast
  1. Posts : 33
    Windows 7 Ultimate Professional Media Center 6.01.7601 Service Pack 1 (32-bit)
    Hey, recently i've been having a problem when trying to move ISO files from one harddrive to another. I've tried with 3 different ISO files and all come up with the same error:
    "An unexpected error is keeping you from copying the file. If you continue to receive this error, you can use the error code to search for help with this problem.
    Error 0x80070570: The file or directory is corrupted and unreadable."
    First time I got this error i just thought something had gone wrong with the download so i deleted the file and downloaded it again. Same problem. This made me think that maybe it was just that download but now I have tried 2 other files and gotten the same error every time.
    This only happens with ISO files though as in case it was the harddrive or connection issue I tried trasferring some other .avi files and they went across without problem.
    Any help would be appreciated.
    Thanks.
  2. Posts : 1,872
    Windows 10 Pro x64, Windows 8.1 Pro x64, Windows 7 Ultimate x64 SP1,
    Are you transfering to an external hard drive?
    Is the target drive formated to NTFS?
    What are the sizes of the iso files?
  3. Posts : 10,796
    perform a chkdsk of source and destination disk
    chkdsk/f y:
    replace y with actual drive letter
  4. Posts : 33
    It was a Seagate 2tb External but there are problems with this model and i had to preform a 'fix' by removing the casing so it is essentially now an internal hard drive.
    Both hard drives are NTFS format.
    Most recent ISO file i have tried was roughly 6.5gb.
    chkdsk/f y:
    Source:
    C:\Users\Matt>chkdsk/f C:
    The type of the file system is NTFS.
    Cannot lock current drive.
    Chkdsk cannot run because the volume is in use by another
    process. Would you like to schedule this volume to be
    checked the next time the system restarts? (Y/N)
    Destination:
    C:\Users\Matt>chkdsk/f E:
    Volume label is New Volume.
    CHKDSK is verifying files (stage 1 of 3)...
    105728 file records processed.
    File verification completed.
    44 large file records processed.
    0 bad file records processed.
    0 EA records processed.
    0 reparse records processed.
    CHKDSK is verifying indexes (stage 2 of 3)...
    112892 index entries processed.
    Index verification completed.
    0 unindexed files scanned.
    0 unindexed files recovered.
    CHKDSK is verifying security descriptors (stage 3 of 3)...
    105728 file SDs/SIDs processed.
    Security descriptor verification completed.
    3583 data files processed.
    CHKDSK is verifying Usn Journal...
    8677120 USN bytes processed.
    Usn Journal verification completed.
    Windows has checked the file system and found no problems.
    1579253759 KB total disk space.
    810925932 KB in 101981 files.
    46596 KB in 3584 indexes.
    0 KB in bad sectors.
    228487 KB in use by the system.
    65536 KB occupied by the log file.
    768052744 KB available on disk.
    4096 bytes in each allocation unit.
    394813439 total allocation units on disk.
    192013186 allocation units available on disk.
  5. Posts : 10,796
    respond Y and reboot. no errors?
  6. Posts : 33
    Responded Y and rebooted. CHKDSK checked C: and went to login screen. Tried to move the ISO file again and came up with the same error.
  7. Posts : 10,796
    Very strange. rename Somefile.iso to somefile.txt and try to copy again. Copy works now?
  8. Posts : 2,528
    Windows 7 x64 Ultimate
    It might be helpful to try to track down what type of controller (Intel XXX, Marvel, ???) your drives are connected too, the mode (IDE/AHCI/RAID etc) and the driver installed (Intel, Microsoft, Marvell etc). This could be indicative of a bug in the combination of your current components
    Are those the only two drives you have? I.e. if you had three drives, would copying between any other two drives also show the problem? Would be good to be able to isolate the problem to a single drive as opposed to a system wide issue. (Maybe try copying the file from one location to another on the same drive, on both drives).
    And I assume you are just drag/drop or cut/paste with explorer itself, not some third party file tool?
  9. Posts : 10,796
    Can you copy a large ISO from C-drive to C-drive?
    Can you copy a large ISO from F-drive to F-drive?
  10. Posts : 33
    Nope still the same error. Im starting to think it might be the directory and not the file somehow.
