Window 7 harddisk preventing start up need help to repair!!!!
i was updating it while i accidently hit the power source button in the back which i thought no problem rebooting but it suddenly prevent it from starting up so i ran the startup repair and it told me to either contact your system admin or compter manufacturer to determine if you need to repair or replace the disk
here is the error message i just need to know if i have to replace it or i can repair it myself
Startup Repair disgnosis and repaid log
Number of repair attempts: 2
Session details
System Dusk = \Device\Harddisk0
Window directory = D:\Windows
AutoChk Run= 0
Number of root causes = 1
Test Performed:
Name: System disk test
Result: Completed successfully. Error code = 0x0
Time taken = 0 ms
Test preformed:
Name: Disk failure diagnosis
Result: Completed successfully. Error code 0x0
Time taken = 375 ms
Root cause found:
Badhard dusk:
