Building a pc - NEED HELP
  1. Posts : 22
    Hey I have one question(or more, I dont know). Will this components be compatible if not recommend me something else, it cant be costing more than the price I type! This is what I was thinking to build! One more question- can you recommend me a not to expensive cooling fan (for processor) which I can OverClock a little bit with!? Please the fan must be from AMAZON!
    Here are the specs:
    Chassis: Cooler Master HAF ATX Mid Tower Case 922 - 89$
    Motherboard: Asus P9X79 DELUXE Intel X79 So.2011 Quad Channel DDR3 ATX Retail - 380
    Processor: Intel Core i7 3820 4x 3.60GHz So.2011 WOF – 310$
    GPU: 3072MB PowerColor Radeon HD 7950 – 430$
    RAM: Corsair 16GB XMS3 (2x 8GB) DDR3 1600Mhz - 110$
    PSU: CORSAIR Enthusiast Series TX750 -105$
    Optical Drive: Asus 24xDVD-RW Serial ATA Internal OEM Drive – 22$
    Total: 1448$
  2. Posts : 5,795
    If you don't need a case quite that big, I can't recommend the HAF912 enough....plus it's cheaper.
    Cooler Master also makes a Hyper 212 Evo, I think, that should allow you plenty of OC'ing headroom. I have two of the Hyper 212+ models, and they are quiet and perform very well....and are very cheap.
    Samsung optical drives work very well and are just as cheap. I'm not a big Asus guy, so maybe that's just an opinion.
  3. Posts : 12,012
    I don't see any hard drives listed. Did you forget or do you already have hard drives?
    Looks like you have a relatively high budget. I'd certainly get an SSD for the operating system and programs and a standard HDD for data. SSD: Intel or Samsung; HDD: Western Digital or Samsung.
    You likely won't need 16 GB of RAM, but you may have an unusual circumstance requiring that much?
    Is there a particular reason you chose that motherboard?? Do you need 8 RAM slots?
  4. Posts : 22
    HDD
    Sorry I have HDD but not in the list - forgot to copy
  5. Posts : 22
    Components!
    Can you please give me a suggestion for CPU, GPU, HDD, PSU, RAM, Optical Drive?
    (from amazon(I live in norway and amazon ships there))
  6. Posts : 22
    Its gonna be REALLY GAMING PC! - max 1425$(20$ more is no big deal)
  7. Posts : 12,012
    What you have chosen looks pretty good, excluding hard drives.
    Post a link to the Amazon site from which you will purchase.
    The Coolermaster Hyper 212 that Deacon mentioned is a good choice.
    I'd definitely get an SSD.
  8. Posts : 22
    Can you please link me all new specs of what u recommend? like CPU,PSU,RAM etc..?
  9. Posts : 12,012
    Post a link to the site from which you will buy.
    How many hard drives will you need?
    If the site is not in English, I can't help much.
  10. Posts : 22
    In the start one! - I wanna buy from amazon.com
