#21
To clarify: you connect the ethernet cable from your modem to the port labled WAN on the router.
The other 3 ports are used to connect PC's directly to the router using an ethernet cable.
Ethernet cables are cheap. Buy one or borrow one. You can then test the router to determine if your original problem is caused by the router or an external source.
