Power supply problems?
I own a Dell Optiplex 745, minitower, and I do not understand what my problem is. It has a standard, 350 watt power supply with a 24 pin connector and I tried to replace it with a new ATX 750 watt power supply with the same 24 pin connector. I plugged in everything properly (I triple checked) and every time I try to start the computer, the Dell loading screen pops up as usual, but it stops loading and the computer makes a rapid beeping sound and stays like that (with the loading screen frozen and computer beeping) till you turn it off. Is there a way for me to tell if the power supply is bad or if it's not compatible with my computer..?
