what is the difference between basic and dynamic type of hdd volume
  1. Posts : 23
    windows 7 ultimate x64 bit
    i am attaching the pics of the disc management and there in the type of the drive like c , d , e etc there is ''dynamic'' . but in some pc i have seen there is '' basic''. so how my drive type changed to the dynamics>? is there any draw back being dynami type drive? if yes then how can i change the type of drive from dynamic to basic. please help
    regards to all helpers
    Attached Thumbnails Attached Thumbnails what is the difference between basic and dynamic type of hdd volume-dynamics.jpg
  2. Posts : 10,994
    Win 7 Pro 64-bit
    This article may help explain the diffrence between basic and dynamic discs.
    The Difference Between Basic and Dynamic Hard Disks - PC Hardware - Find Free Computer Help Tips Online
    After a basic disk is converted to a dynamic disk, it cannot be converted back without losing your data. If you want to go back make sure to back up your files first. You must first delete all dynamic volumes on the disk and then convert the dynamic disk back to a basic disk.
  3. Posts : 23
    thank you ffor the response. i have read some where i cannot install new operating system in dynamic hard drive, is it true? it means if i wanted to re instal window seven or wanted to install window 8 then is it impossibe in this dynamic hard drive? please suggest me the truth
  4. Posts : 10,994
    Win 7 Pro 64-bit
    According to this Microsoft Answers forum thread, if you convert the disk(s) to dynamic, you will not be able to start installed operating systems from any volume on the disk(s) (except the current boot volume).
    Dynamic disks are not supported by this operating system or server - Microsoft Answers
    Starting with Vista/Server 2008, the operating system's installation program doesn't allow the operating system to be installed on a dynamic disk. It's all related to security issues. This Microsoft KB article explains that if the hard disk on which you want to install Windows Vista, Windows 7 or Windows Server 2008 R2 is a dynamic disk, you will probably receive a "Windows is unable to find a system volume that meets its criteria for installation" error message. So it's safer to install your operating system on a basic disk. One of our own Forum members (gregrocker) who is also a microsoft MVP says the same thing.
    You cannot select or format a hard disk partition when you try to install Windows Vista, Windows 7 or Windows Server 2008 R2
    can I install windows 7 on a dynamic disk?
  5. Posts : 23
    thank you for the suggestion, so how to convert dynamic to basic? i have heard all the data from each volume will be deleted. so i dont wnat to loose the data so is there any method for this? or by using third party application like partition manager , can i change it without the deletion of the data from drive? if u know any partition manager please suggest me friend.
    regards
  6. Posts : 10,994
    Win 7 Pro 64-bit
    Here's how to convert from dynamic to basic disk.
    Convert a Dynamic Disk to a Basic Disk
    As far as I know, you must backup and save any data on the drive before converting it. It's not possible to leave "dynamic data" on a drive that's been converted back to basic because all dynamic partitions/volumes will be deleted. Depending on how much data you have (and from your disk management screenshot it looks like you've got about 450GB) you might want to invest in an external hard drive. From the above tutorial:
       Warning
    Before you convert a dynamic disk to a basic disk, be sure to backup anything that you do not want to lose on that dynamic disk. Converting the dynamic disk back to a basic disk requires that all dynamic volumes are deleted on the disk first.
  7. Posts : 23
    thank u for ur suggestion my frens. i used mini tool partition manager to convert this taking the risk and perhaps i got it. i have attached it. please look it and suggest me that is it ok now to basic or still it is in dynamics? waiting ur reply
    regards
    Attached Thumbnails Attached Thumbnails what is the difference between basic and dynamic type of hdd volume-uttam.jpg
  8. Posts : 10,994
    Win 7 Pro 64-bit
    The screenshot shows it's been converted. Have you tried to access any of your data?
  9. Posts : 23
    yeah, i have opened the drive and played the stored movie , played the song and installed the program too, . more important thing is the restore point that were lost when the disk were converted to the dynamics . again reappeared.
    i think i got Ur question or you mean to ask some thing else?
    regards
  10. Posts : 10,994
    Win 7 Pro 64-bit
    Looks like you got it all sorted out! And I learned something new about the Mini Tool.
