Problem with exFAT USB Flash Drive
Page 1 of 3 123 LastLast
  1. Posts : 33
    Windows 7 Home Edition x86
    Hi Everyone
    I have recently encountered a problem when I first bought a USB Flash Drive 128 GB.
    It's exFAT Format, Whenever I Add files to it, then re-plug it in, the files become corrupted, And i will not be able to open any.
    I have tried to open the files but no luck :/,
    I'm Using Windows 7 Home Edition and Dell Inspiron 1520 Intel Core 2 Duo, RAM
    2.5 GB
    Thank you.
  2. Posts : 357
    Windows 7 Home Pre
    What size are these files. And Are you "Safely removing USB device" of just unplugging.
  3. Posts : 33
    I'm safely removing it, and whatever the size of the file is. it keeps giving me errors
  4. Posts : 357
    Windows 7 Home Pre
    Have you looked on the site manufactures for a firmware update. Or Format it into Fat32 or NTFS
  5. Posts : 33
    There is no luck into formatting it into NTFS, the formatting process always fail. Please help me, I really don't want to throw the Drive Away
  6. whs
    exFat is not supported in Windows 7. Either you reformat or you donate the stick to someone who has and old OS. Try another formatting program.
  7. Posts : 33
    I tried this software here HP USB Disk Storage Format Tool Download - Softpedia
    but it didn't work.
    I need your help seriously, this is the strangest problem I face :/
  8. whs
  9. Posts : 25,847
    What brand of flash drive do you have. Their has been reports of many counterfeit flash drives that just don't work.
    EXAMPLE.
    http://www.amazon.com/Kingston-DataT...owViewpoints=0
    Kingston Technology Company - Company - Memory Verification
  10. Posts : 33
    ok well I converted the Flash Drive from exFAT to FAT32. but I don't see any difference. I tired the program you gave me and still no luck :/
    I got the flash drive from china, maybe it's a poor type or something ?
