USB Flash Drive problems
Page 2 of 2 FirstFirst 12
  1. Posts : 46
    Interesting, so it does the samething also with nVidia chipset. I also got most recent AMD chipset drivers, so most likely the problem is not with the chipset but something else...
  2. Posts : 2
    Windows
       #12
    I am also having USB flash drive issue I am using Toshiba 4gb Transmemory flash drive. This problem surfaces only after I made windows updation via internet.
    But I find that if my system is under safe mode, OS is detecting pendrive.
    Already googled this problem, many people facing the same issue.
  3. Posts : 2
    Windows
    Yesterday My problem has been solved. I am using BIOSTAR TPOWER X58 motherboard withe Core i7. I have updated motherboard Bios and after the reboot my pendrive is recognizing and working fine.
    Thanks and Regards
