laptop replacement parts question
  1. Posts : 117
    windows xp pro 32-bit
    my laptop's touchpad currently go crazy when im controlling it
    what do you think is it faulty that i have to replace it or its just my system os, already tried restarting and system restore
    what website can i buy this replacement parts and about how much range is this touchpad
    my laptop is Acer Aspire 4750G
  2. Posts : 165
    Windows 7 Ultimate 64
    Try virus scan i know sounds silly.
    Uninstall drivers and re install using these ones :
    http://global-download.acer.com/GDFi...C=ACER&SC=PA_7
    Failing that Is it in warranty ? If it is a problem it may be cheaper buying a spares or repair laptop taking its parts as a last resort.
  3. Posts : 117
    i bought it 10 months ago, it has a 1 year limited warranty for factory defect
    but for personally damaged no warranty
    we didnt even dropped it and it is very rare that we used the touchpad
  4. Posts : 2,171
    Go for the warranty.
  5. Posts : 165
    Yeah for the warranty if its still got 2 months left that is my point id wouldn't hesitate and get it fixed as it could be anything but better get sending off as times ticking till the day they actually get it in their hands.
    Trust me it isnt worth solving yourself when its still in warranty hope that clears it up :)
  6. Posts : 117
    the next day when i removed my battery for a day then i put it back again
    my touchpad is working, i dont know what happend but it works now
    last few months when you press a key from the keyboard (long press) it freezes wwhen you let go of the key it does not freeze
    man whats happening to my laptop
  7. Posts : 2,171
    Dust/dirt interfering with contacts?
