Power supply surge detected every reboot
  1. Posts : 10
    Windows 7 Ultimate x32
    Hi guys
    I get a power supply surge every time I reboot (its been like this for 3 days now) and I have to press f2 to load defaults and continue then it boots up fine.
    I want to know if I absolutely need a new power supply? or is there anything else I can do to resolve this.
    Steve
    Can you explain a little more about what you are calling a "power supply surge"?
  3. Posts : 10
    During boot up it stops at the screen below(see image). And I always have to press f2 key to continue, then it boots up.
    Attached Thumbnails Attached Thumbnails Power supply surge detected every reboot-capture.jpg
  4. Posts : 1,641
    Dual-boot: Windows 7 HP 32-bit SP1 & Windows XP Pro 32-bit SP2.
    What is your PSU?
  5. Posts : 9,582
    Windows 8.1 Pro RTM x64
    By reboot, do you mean a restart (as though you pressed the reset button), a cold boot (system powered off and mains off) or a cold boot (system powered off but mains on) ?
  6. Posts : 10
    a restart (as though I pressed the reset button)
  7. Posts : 9,582
    What about the other scenarios I suggested?
  8. Posts : 10
    Perfect!!! It doesn't do it anymore after trying your other scenarios
    Thanks you guys rock!!!!!
    Steve
  9. Posts : 252
    Windows 7 Ultimate 64-bit
    If something worked for you can you edit your first post to reflect the fix and mark the topic as 'Solved' please? :)
    Mainly because I'm curious to try what you did. I ended up turning off the Asus surge protection on my board due to lack of alternatives.
  10. Posts : 9,582
    That's good to know. Is this now the case for whichever of the 3 methods of shutting down and restarting that I suggested trying above?
