weird drive letter problem?
  1. Posts : 124
    Windows 7 Ultimate x64, Windows 8.1 Pro x64 (on laptop)
    hello guys, so i had this random problems where my external hard drive has changed to the letter (F: ) which is inconvenient as many of the music production programs I use require the drive letter (G: ) and this letter is now showing as a 'portable device' i will provide screenshots below, I have tried Disk management and also Uninstalling the driver for whatever is taking up (G: ) at this moment in time, can anyone help me please?
    thank-you in advance.
    ===edit===
    click pictures for full view.
  2. Posts : 184
    You leave the Hitachi drive connected all the time?
    I think the current "G" is the HP-Tools partition which is hidden. Unplug the Hitachi, reboot & see what happens when you plug it in after the boot is completed. You can verify this with Easeus Partition Master.
    You can "fix" USB drive letter assignments with this: USB Drive Letter Manager - USBDLM
  3. Posts : 124
    i do leave the hitatchi connected all the time yes, it has all my samples and programs i will try your solution now and get back to you, one moment :).
  4. Posts : 124
    no it doesnt work still letter F :c
  5. Posts : 774
    Vista Ultimate X64/ Windows 7 Dual-boot
    In Disk Management give the external drive a Volume Label...it can be anything you want.
    Then assign it the drive letter you want and re-boot.
    It will now retain that letter ...so long as you picked one thats not in use.
  6. Posts : 6,668
    Windows 7 x64
    I've reserved the drive letter s-z on all my systems for years now for partitions and devices that refuse to accept the drive assignments I have given them.
    To get the G letter off that drive just extend it to a letter you'll likely never use for anything else.
  7. Posts : 1,711
    Win 7 Pro 64-bit 7601
    It's years that I have an external USB HDD that has a volume label and is letter Z (just to make sure it does not pick a new letter and screw up links).
    And to deal with partitions and drive letters and things I always used EaseUs partition master (which is free).
  8. Posts : 124
    thankyou all! i changed it to drive letter Z and just reinstalled some programs :)
