Battery plugged in, not charging. Not the normal problem.
  1. Posts : 15
    Windows 7 Home Premium 64 bit
    I've got a problem, my battery wont charge.
    I used to get this, but re installing ACPI-Compliant Control Method Battery would normally solve this problem. Now after i remove ac, the laptop shuts down. I also got a screen once that saying my battery can now store less. When I click on the battery icon, it says plugged in and not charging.
    Please help,
    Paradoxex
  2. Posts : 6,243
    Hi ParadoXeX, How old is the battery? Do you "condition" the battery ? do you Know for definate the laptops charger board is working ? have a look here see if this helps in any way What To Do If Your Laptop Is Plugged In But Not Charging | PCMag.com
  3. Posts : 2,240
    Windows 7 Ultimate 64 bit
    What's the brand of your laptop? Some laptop manufacturers have special diagnostic software to test the battery of the laptop to see if it can be salvaged or replaced.
  4. Posts : 15
    It is an HP DV6, It's the battery that came with the laptop, about maybe 2 years old now?
    What do you mean by condition the battery? I'll look up the site now.
