Problems after running SeaTools
Hi all :)
This started after I ran SeaTools for Windows, Long generic test..which passed but I'm having few issues ever since:
- I usually turn off my computer before going to bed, but the morning after I took the test when I powered up my computer it started with this hearable vibration. I could even feel it when I touched the front part of the computer case. The vibration & sound lessened gradually & I thought I was okay until I opened speccy & saw that the Celsius of the hard drive was at 50 within 45 mins of use.
- This happened once more that day & I consulted with Arc. He suggested me to run disk check on the hard drive by re-seating & cleaning the cables etc which I did with no problems found. I even unscrewed, cleaned the hard drive & switched locations. Made sure I screwed it firm & tight.
- There were no vibration/sound/celsius problem until yesterday afternoon when I went home for lunch. I booted normally & there it was vibrating again.
So I ran disk check again, ran puran defrag, ran the default windows defrag. Downloaded & installed crystal disk info. Attached some snips but this is of when I just booted up. The numbers changed gradually after use and the celsius went to 50 later.
Anyway, the pc booted up normally today morning. But appreciate any advice & opinions on this problem. I have a feeling this stuff is gonna reoccur every few days but have no idea why a sea tools test would do this to a hard disk. Everything was fine before I did the test.
Thanks for reading
