External Hard Drive Problem :(
  1. Posts : 1
    Window 7 Professional x64
    I think Mere Hard Drive mai Virus hai. Hard Drive ki space y show kar rai hai k external hard mai data hai . but in folder wo show nai ho rha ......
    My Hard drive show data space in properties . But Data not show in drive . I this Its virus. Kindly recomend good Antivirus software
  2. Posts : 10,994
    Win 7 Pro 64-bit
    Hello Tariq and welcome to Seven Forums.
    You can try the free version of Malwarebytes. It is highly recommended on this Forum. After installing on your computer make sure you get the latest updates. Select Full Scan. Then select which drive(s) you want to scan. A full scan could take over an hour.
    Malwarebytes : Malwarebytes Anti-Malware removes malware including viruses, spyware, worms and trojans, plus it protects your computer
  3. Posts : 6,458
    Tariq: Eset online scanner is also very well regarded. It is also free. I would run both Malwarebytes and Eset scanner, but not at the same time. run one, then the other.
    These are both scanners, not real-time protection.
    Consider free AV - Microsoft Security Essentials, or Avast, or AVG. You only need one, more than one AV program can cause issues as they tend to compete for resources and they might consider the other application a security risk. So only run one real-time AV program on your system.
