Wireless Mouse Issue -- does not work
  1. Posts : 7
    Windows XP
    I have a wireless mouse with a wired receiver hooked into the port with a USB to Ps2 adapter... I have had no problems until recently when the mouse was showing low battery...I installed the correct batteries and it still blinks red/low battery and the pointer on the screen stays on the middle of the screen after startup... I bought a new adapter, same thing, I bought a new wireless mouse with plug in receiver, nothing....
    I have yet to try a corded mouse....
  2. Posts : 7
    Windows XP
    Can anyone help me figure out why it is doing this ?
  3. Posts : 9,600
    Win 7 Ultimate 64 bit
    This is a long shot but try plugging the receiver into a USB port instead of the PS/2 to USB adapter. I've had devices that would work with such an adapter and even more that wouldn't.
  4. Posts : 7
    Windows XP
    Thank you Lady F... I found an old mouse with PS2 plug and it worked... I guess my system isn't recognizing wireless anymore... I had bought a new wireless mouse with plug in receiver and it too did not work.
  5. Posts : 1,711
    Win 7 Pro 64-bit 7601
    hmmm, theoretically the computer just sees a USB mouse, the whole wireless communication part is handled by the usb dongle and the mouse.
    Do you have other USB devices? Do they work fine? Where did you plug them (front or back ports)?
  6. Posts : 7
    Windows XP
    bob, I don't use any USB ports for anything... I only tried all 6 with the new wireless receiver plug in...
  7. Posts : 4,466
    Windows 10 Education 64 bit
    What does device manger show? Any unknown devices or devices with a yellow ! after them.
