Need help with wireless printer
I bought a new wireless Epson Workforce 545 printer. It has worked without flow for quite some time (nearly a year). Now all the suddenly it wont print.I have it as a shared printer. There are three other family members on the network and all three others print without any problem. Mine worked fine and now wont print. It goes through the motions and then times out. All it says is "printer error". Nothing has changed. I have not installed anything new or made any other changes. I uninstalled it and then re installed it using the manufacturers software. It appears fine until you print. Where do i go from here?
