Changed case - Internal USB Card Reader does not work
Last night I moved to a new case. Everything is perfect but my internal USB card reader just does not work anymore.
The only difference between the two cases is that the new one has 2 x USB 3.0 and 2 x USB 2.0 in the front panel. The old one had one each.
The reader is recognized and shows in device manager as working properly.
Tried uninstalling and rebooting, it installs OK, but doesn't work.
The USB slot in the reader works just fine.
Memory cards work if they are empty, but if I insert one with JPGs in it, I only see generic icons and when trying to preview them I get the following error:
COM Surrogate has stopped working.
Then Windows Explorer freezes, hangs and restarts.
Any ideas?
Thanks for your help,
J
