Create a permanant drive letter for USB Stick Drive
  1. Posts : 119
    Windows 7 Ultimate
    Can Someone please tell me how I create a permanent drive letter for a USB Stick Drive? Say Z: ?? So When I boot to it it will always go to that drive letter? Thank you Very much John
  2. Posts : 3,300
    Win7 Home Premium 64x
    yes, but it will only work on the computer that you are setting this up on.
    Go to Control Panel > Administrative Tools > Computer Management > Disk Management
    Select the USB drive in the graphical layout. right click and go to Change Drive letter
    Assign it a drive letter and click OK. Now when you plug it into the computer, it will show up with that drive letter. or it should....
    This won't carry over to other computers.
    Shortcut: type in "Disk Management" in the start menu search bar and select "Create and format hard disk partitions"
  3. Posts : 414
    win7 ultimate 32bit
    plug in USB drive--go to Computer Management>Disk Management--right click the disk - select 'Change drive letter and paths' -the drive should be highlighted--select 'change' - assign drive letter - click OK and OK....done!
    Attached Thumbnails Attached Thumbnails Create a permanant drive letter for USB Stick Drive-capture.jpg
  4. Posts : 10
    Windows 7 32 bit
    Type diskmgmt.msc in run box Select the USB drive in the graphical layout. right click and go to Change Drive letter
    Assign the drive letter and click OK. Now when you plug it into the computer, it will show up with that drive letter.......
  5. Posts : 774
    Vista Ultimate X64/ Windows 7 Dual-boot
    If you want the USB stick to retain the drive letter on other PC's 1st of all select a seldom used drive letter...say from the middle of the alphabet down...
    Then after assigning it in Disk Management also give the stik a Volume Label...it can be any name you want.
    This will make it retain the drive letter on any PC...the only time it will change is if it's used on a PC that already uses that drive letter.
