Need help with new power supply purchase
  1. Posts : 123
    Windows 7 Home premium 64bit
    Hey there I'm going to upgrade my power supply of 400W to 700W+, but I'm not sure if it will be compatible with my current hardware.
    Current hardware:
    Graphics card: NVIDIA GeForce GTX 550 Ti
    CPU: AMD Athlon II x4 620
    RAM: 6GB Dual-Channel DDR2 @399MHz
    Motherboard: Acer RS780HVF (AM2)
    Hard Drives: 699GB Western Digital WDC WD7501AALS-00J7B1 ATA Device (SATA) [x2]
    Speccy Spec snapshot: http://speccy.piriform.com/results/5...AH7lPclRqaxxWP
    Thanks in advance
  2. Posts : 109
    Windows 7 Home Premium 64Bit (Service Pack 1)
    Hi Thomaszee, im not an expert on PSU's but i have a 650w PSU in my machine and there is no problem there, and from what i can see from your spec you shouldnt have a problem with a 700w+, just make sure you purchase from a decent manufacturer.
    Also if i am right in thinking (correct me if im wrong) also gotta look at the 12v rail? to make sure there will be enough power to the GPU??
    Also to save writing out your system spec for each post, update your system spec
    Hope it helps :)
    Regards
    Toby
  3. Posts : 123
    I'm planning on buying a corsair PSU, most of them have a 12v rail so should be fine on that :)
  4. Posts : 6,292
    You can use this tool:
    eXtreme Power Supply Calculator
    to calculate what you need.
    Don't forget to fill in the last box: Capacitor Aging. This compensates for the known loss in power that happens as your power supply gets older. The general rule of thumb is to enter 10% for each year you expect to use the supply in your system.
  5. Posts : 2,606
    Windows 7 Pro X64 SP1
    eVGA recommends a power supply with at least 400W and 24A at +12V for their 550ti card.
    Aside from that, your graphics card needs a PCI-E 6 pin auxiliary power connector. (A Molex-to-PCI-E adapter would be an alternative, but it's best to not use adapters.) It needs a 24 pin pin ATX power connector. (20+4 would be fine.) It also needs a 4 pin ATX 12V power connector for the CPU.
    Why are you upgrading the PSU? If you have a good 400W one, it's adequate. It would make sense to put a higher powered graphics card in this oldish PC.
    If you have the money, it might make sense to buy a larger capacity PSU that can follow you through future upgrades. My old PC Power & Cooling Silencer 750 has lived in several cases. Its electrolytic capacitors haven't shown any tendency to die yet.
  6. Posts : 123
    Well, the graphics card requires 500W on itself (recommendation on nvidia website) and it also has to feed all other components.
  7. Posts : 6,879
    Win 7 Ultimate x64
    No the card doesn't require 500W itself. That 500W that video card manufacturer's recommend is for the system total, and is always higher than actually needed to take into account people using low quality no name power supplies.
    This,
    ASUS GeForce GTX 550 Ti Direct CU 1 GB Review | techPowerUp
    will give you an idea of what the card actually uses.
  8. Posts : 13,576
    A Corsair 700 will be more than adequate. Which model were you thinking of getting ?
    http://www.newegg.com/Product/Produc...82E16817139010
    http://www.tigerdirect.com/applicati...35_37813_51107
    http://www.newegg.com/Power-Supplies/Category/ID-32
    Just for research purposes, not sure if they ship to you.
    My new one will be the HX750
  9. Posts : 123
    CORSAIR HX Series HX750 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply - Newegg.com
    Corsair Power Supplies 700W - 999W Wattage at TigerDirect.com
    Power Supplies - Newegg.com
    Still deciding on which to buy but that one does look good indeed
  10. Posts : 13,576
