Just as side issue bortelli if you want to find some RAM for that board try the G Skill forum - thats all Tradesman does - RAM related stuff.
Welcome to the G.SKILL TECH FORUM
About two days ago I realized that my icon that displays that I am connected to the internet says "Not connected - no connections are available". Yet I can go on the internet just fine. I've uninstalled and reinstaled my networks drivers, and I still displays the same message. Thats a little strange.
Not exactly, but you should activate it. It is not a big hassle to activate windows.
The possible problem is that you havent updated display driver yet, as I am seeing
Stress test the Graphics Card using Furmark.Code:*** WARNING: Unable to verify timestamp for atikmdag.sys *** ERROR: Module load completed but symbols could not be loaded for atikmdag.sys ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* Use !analyze -v to get detailed debugging information. BugCheck A0000001, {5, 0, 0, 0} Probably caused by : atikmdag.sys ( atikmdag+2311c ) Followup: MachineOwner --------- 3: kd> !analyze -v ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* Unknown bugcheck code (a0000001) Unknown bugcheck description Arguments: Arg1: 0000000000000005 Arg2: 0000000000000000 Arg3: 0000000000000000 Arg4: 0000000000000000 Debugging Details: ------------------ CUSTOMER_CRASH_COUNT: 1 DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT BUGCHECK_STR: 0xA0000001 PROCESS_NAME: System CURRENT_IRQL: b TAG_NOT_DEFINED_c000000f: FFFFF88001EFDFB0 LAST_CONTROL_TRANSFER: from fffff880074df11c to fffff80001adac40 STACK_TEXT: fffff880`01ef6648 fffff880`074df11c : 00000000`a0000001 00000000`00000005 00000000`00000000 00000000`00000000 : nt!KeBugCheckEx fffff880`01ef6650 00000000`a0000001 : 00000000`00000005 00000000`00000000 00000000`00000000 00000000`00000000 : atikmdag+0x2311c fffff880`01ef6658 00000000`00000005 : 00000000`00000000 00000000`00000000 00000000`00000000 fffffa80`093618a8 : 0xa0000001 fffff880`01ef6660 00000000`00000000 : 00000000`00000000 00000000`00000000 fffffa80`093618a8 fffff880`01ef66b0 : 0x5 STACK_COMMAND: kb FOLLOWUP_IP: atikmdag+2311c fffff880`074df11c ?? ??? SYMBOL_STACK_INDEX: 1 SYMBOL_NAME: atikmdag+2311c FOLLOWUP_NAME: MachineOwner MODULE_NAME: atikmdag IMAGE_NAME: atikmdag.sys DEBUG_FLR_IMAGE_TIMESTAMP: 50d225df FAILURE_BUCKET_ID: X64_0xA0000001_atikmdag+2311c BUCKET_ID: X64_0xA0000001_atikmdag+2311c Followup: MachineOwner --------- 3: kd> lmvm atikmdag start end module name fffff880`074bc000 fffff880`07fd2000 atikmdag T (no symbols) Loaded symbol image file: atikmdag.sys Image path: \SystemRoot\system32\DRIVERS\atikmdag.sys Image name: atikmdag.sys Timestamp: Thu Dec 20 02:08:55 2012 (50D225DF) CheckSum: 00AC6529 ImageSize: 00B16000 Translations: 0000.04b0 0000.04e4 0409.04b0 0409.04e4
Video Card - Stress Test with Furmark
Is the computer hot? Report us the heat of the computer after a couple of hours of your normal usage. Upload a screenshot of the summery tab of Speccy.
Check the power supply with eXtreme Power Supply Calculator
When using furmark, my graphics card capped at around 64'c.
I used The power supply tool you mentioned, I guess thats in case I need another one?
And this Time I Did update my display driver, and I still crashed. Also I dont have any bluetooth enabled devices, and for some reason It stills says I am not connected to the internet.
Here is the crash and speccy screenshot.
This crash also indicates to the display driver, despite of it being updated. So it is not the problem if the driver itself as far as I guess.
Nothing is overheating as per speccy. And 64 degrees is not a high temp for a stress test at all. Have you noticed any artifacts or abnormalities during the Furmark test?
About PSU, what's the result you got there? Is it supplying adequate power or less? If less, all the problems are possible.
BTW, can you use the onboard graphics to observe is it failing there too or not?
I know this thread is a little aged, but I finaly came across a permanent solution. After loading my Bios to fail-safe defaults, everything is ok.
