Help Network Adapter Problem wont uninstall drivers
just got home today and turned on the PC to my dismay I no internet connection on my Primary OS 32bit windows 7 so I went into device manager and got this error
so I uninstalled it but it just plainsly disappear and did not ask me to delete the driver files like it would normally do and I tried to reinstall my Driver but got this error
The Realtek Network Controller was not found. If Deep Sleep Mode is enabled Please Plug the Cable.
so I am preety stumped on what to do so I tried doing an SFC /SCANNOW and hope it will fix it after that I got the message that it weren't able to fix some files and gave me a loaction for the logs its still the same I am preety annoyed by it since my Internet is working fine on my secondary OS which is a 64bit windows 7 I am even using it right now as I type this
SO help me PLZ if you need me to post my SFC logs I will
