My front USB 3 port doesn't read USB 3 device, but reads USB 2 device
I have ASUS P8Z77 –V motherboard and the front USB 3.0 headers are not working when I plug in a USB 3.0 device. When I plugged in my Kingston USB 3.0 Flash Drive into the front USB 3.0 header it didn't work. As in, when I tried to move a file into the flash drive, the drive disappears and it makes that USB unplugged sound. But if I connect it to any back USB 3.0 ports, it works fine.
But, if I plug in my Scandisk USB 2.0 Flash drive into the front USB 3.0 ports, it works without any errors.
This only happens with USB 3.0 devices and it has to be connected to front USB 3.0 ports.
I have installed all the latest drivers and updated my BIOS to the latest one. I have checked if USB 3.0 is enabled in BIOS.
I asked to my friend to help me. He has AMD rig with ASUS M5a99X EVO motherboard, which has a front USB 3.0 header. We installed all AMD drivers for his rig updated everything, the front USB 3.0 ports worked fine. We manage to transfer all the files at full-speed on to the Kingston 3.0 flash drive without any errors, so I know it’s not my PC case’s USB 3.0 cable at fault.
Any help. Please note the front USB 3.0 ports work if I plug in a USB 2.0 device.
