CPU fan speed
Page 1 of 5 123 ... LastLast
  1. Posts : 1,568
    Windows 8.1.1 64bit
    CPU fan speed
    Installed a Cooler Master Gemin II S524 cpu cooler yesterday.
    The speed has been staying from 450 - 470 rpm. / Temp. 22c - 27c
    Is there a program to control the fan speed ?
  2. Posts : 37
    Sorry no idea on fan speed software, but wow that thing is huge! And pretty cool(no pun...well yea it was intended). Looks like the radiator from a small car, heh.
  3. Posts : 5,915
    Windows 10 Pro X64
    You can adjust some of the fan settings in your Bios usually. There are also options like speedfan. Just remember, the faster the fan speed the louder it gets.
  4. Posts : 24,479
    Windows 7 Ultimate X64 SP1
    The program may be misreading your RPM. It says max is 37,500.
  5. Posts : 1,568
    Windows 8.1.1 64bit
    Thank's for the quick replies.
    Yes, agreed both the cpu and case fan speeds do this when I start the program, did a clear min./max. now looks normal.
    So there is no way to increase the cpu speed ?
    or is it controlled by a sensor and is increased or decreased by the cpu temp. alone ?
  6. Posts : 5,915
    Windows 10 Pro X64
    I agree with Britton30 that it is misreading your rpm. Your temps are fine.
  7. Posts : 24,479
    Run Intel Burn test on default settings, it will heat up your CPU but keep a careful eye on your temps and fans, the should speed up through the BIOS controls. It may cause a BSOD, but don't worry, it'll restart fine.
    download from Guru3D.com
  8. Posts : 1,568
    Windows 8.1.1 64bit
    OK, I'll give it a try.
  9. Posts : 1,568
    Windows 8.1.1 64bit
    I have a AMD cpu, doe's it make a difference in running this program ?
  10. Posts : 5,915
    Windows 10 Pro X64
    Computiac, it works with AMD too.
