CPU fan speed
  1. Posts : 1,568
    Windows 8.1.1 64bit
    OK, thank's Dude.
  2. Posts : 1,568
    Windows 8.1.1 64bit
       #12
    Test went well, no BSOD. Even though temp of cpu went up quite a bit the fan rpm did not increase all that much.
    The left pic. is after test, notice the max. results.
    Everything look good ?
  3. Posts : 24,479
    Windows 7 Ultimate X64 SP1
    Max temp isn't bad, on my AMDs it will hit 70C. What is the rated fan speed on that cooler? Also what motherboard?
  4. Posts : 5,915
    Windows 10 Pro X64
       #14
    Try a run with with maximum settings, 5 test should do.
  5. Posts : 1,568
    Windows 8.1.1 64bit
       #15
    MB is Foxconn 2AB1
    AMD Phenom(tm) II X4 840T Processor, not the 940 stated in the CPUID specs.
    Rated fan speed is 800 - 1800 rpm +/- 10%
    Should I go ahead with the test Dude suggested now ?
  6. Posts : 24,479
       #16
    Well, max setting REALLY heat an AMD CPU, just keep an eye on the temps real close and stop the test if you get to around 66C.
  7. Posts : 1,568
    Windows 8.1.1 64bit
       #17
    OK, will do.
  8. Posts : 24,479
       #18
    I found the max temp for a X4 840 (not 840T) is 71C.
    Is this http://h10025.www1.hp.com/ewfrf/wc/d...=c02628244#N98 your computer? I researched the motherboard and it's a HP OEM board. I can't seem to find any manuals on it, I was looking for fan speed settings in the BIOS. If it's possible, turn off Cool'n'Quiet.
  9. Posts : 5,915
    Windows 10 Pro X64
       #19
    Are you talking Tcase or Tj max temp Britton30? Not trying to derail the thread just curious
  10. Posts : 1,568
    Windows 8.1.1 64bit
       #20
    The test took a long time, but finally failed.
    Is this normal or should I run the test again ?
    The thing I noticed most was the PSU fan increased in both RPM and noise.
