OK, thank's Dude.
Test went well, no BSOD. Even though temp of cpu went up quite a bit the fan rpm did not increase all that much.
The left pic. is after test, notice the max. results.
Everything look good ?
Max temp isn't bad, on my AMDs it will hit 70C. What is the rated fan speed on that cooler? Also what motherboard?
Well, max setting REALLY heat an AMD CPU, just keep an eye on the temps real close and stop the test if you get to around 66C.
I found the max temp for a X4 840 (not 840T) is 71C.
Is this http://h10025.www1.hp.com/ewfrf/wc/d...=c02628244#N98 your computer? I researched the motherboard and it's a HP OEM board. I can't seem to find any manuals on it, I was looking for fan speed settings in the BIOS. If it's possible, turn off Cool'n'Quiet.
The test took a long time, but finally failed.
Is this normal or should I run the test again ?
The thing I noticed most was the PSU fan increased in both RPM and noise.
