#21
I'm going to wait for Britton30 to come back, and ignore my last question. I'm going to start another thread. To me it sounds like the cooler isn't seated good. Did you apply thermal compound? Are you OCing?
From your ss your temp only went up to 52C. I think we should wait for Britton30 or someone else to come in. I don't want to give you bad advice.
I maybe wrong but, if the temps do not go over 52c, then isn't the cooler doing its job while running this test ?
or should the program be making the temps go up no matter what ?
Rerunning the test now, so far with the same results.
It would seem that it was, but the fan speeds have me wondering. Also try core temp and see what that gives you for temps.
How do I stand with the cooler and fan ?
All is good ? , anything to worry about ?
How doe's the shot of core temp look ?
