Computer Type: PC/Desktop System Manufacturer/Model Number: Home Built Desktop By DataTech OS: Windows 7 Ultimate X64 SP1 CPU: Intel i5-2550K, Differing ~4.4-4.8GHz No built in GPU Motherboard: ASUS P8Z68-V PRO/GEN3 Memory: 16GB G.Skill Sniper 1866MHz @ 2133MHz 2x8GB Graphics Card: ASUS GTX650TIB-DC2OC-2GD5, (650TI Boost) Sound Card: Onboard Realtek 5-1 Monitor(s) Displays: Samsung P2570HD Screen Resolution: 1920x1080 Keyboard: E-Z Eyes, bright yellow keys with large characters Mouse: steelseries SENSEI Laser Pro Gaming PSU: Corsair HX650W Case: Inwin Dragon Rider Cooling: Hyper 212 EVO w/two Noctua fans, push-pull, @1300 RPM Hard Drives: Samsung 840 Pro 256GB SSD for OS, 500GB Seagate Constellation (Enterprise drive) for Data Internet Speed: 48-51Mbs Mbs down, 11 Mbs up Xfinity Cable Browser: IE 10, Opera, Pale Moon if needed Antivirus: Norton Internet Security 2013 Other Info: 4 case fans, LG BluRay-RE, ASUS DVD-RW, Mr. Fusion power supply, 1.21 gigawatts.
Hello,
History:
I have had a similar issue in the past with my last PC (which had serious issues and was replaced with this one that is only a few months old now) and got help from these forums, the problem was completely fixed but following the same steps does not work for me this time.
Hi
After a power surge on hub port when attaching a card reader to a front USB port one of my external hard drives disappeared.
The drive works fine and is now on another USB port.
The non functioning rear USB port has the following properties (image 1) and the location address looks...
Hi Everyone
I have recently discovered that my 4 USB port splitter has stopped working suddenly. It is about 4 years old and I am pretty sure it only supports USB devices up to 2.0
http://www.gamesalor.com/dianzi1/d4/9393/1.jpg
I am not exactly sure what caused it to stop working suddenly...
Hey im new to this forum and i am frustrated with my internet :mad:
Im currently using a Western Digital box, wired to the box and to my PC.
It worked for a couple of days then suddenly it stopped working, yellow exclamation mark.
Heres my Ipconfig.
I use windows 7 64 os laptop . Today while working all of a sudden all usb ports stopped working,
I restarted the machine , but the pc couldn't shutdown properly. While shutting down I observed an BSOD.
I have attached the dump file, also I'm using latest drivers.
Can you please...
