[Q] power supply upgrade
  1. Posts : 26
    Windows 7 Ultimate x64 Service pack 1
    hello all i have a emachines w3619 with a ecs 945gct-m3 mobo and was wanting a power supply upgrade.....my mobo is weird though because as you can see in the picture i have two spots for the extra 4-pin connector or so i think....anyways i was wanting to upgrade the psu for a new powerful graphics card so any advice to upgrade will be appriciated
  2. Posts : 9,606
    I would get a download copy of the manual for this MB from the ECS website to verify what all the connections are used for. Plus some MFG computer cases do not always fit the standard replacement PSU's.
  3. Posts : 2,606
    Windows 7 Pro X64 SP1
    Your motherboard has a 24 pin ATX power connector, plus a 4 pin +12V CPU power connector.
    It looks like your system may have been built using a 20 pin ATX power plug, leaving 4 disused pins in the connector. (That's OK, as long as the system is getting enough power.)
    An industry standard ATX power supply, with 24 pin ATX (often 20+4, for native use in either 20 or 24 pin ATX boards) and a 4 pin +12V connector, ought to be OK electrically.
    I can't find whether one would fit in the eMachines case, but from some eBay listings, looks like it ought to.
    Just out of curiosity, why are you upgrading the PSU?
  4. Posts : 26
    Well I want a better PSU because I want a graphics card so I can play games on my PC but most recommend a good 400 watt supply and I have like a 180 watt supply, so yea that's why
  5. Posts : 26
    And I looked for a manual but could not find a free one
  6. Posts : 9,606
    Can you measure the outside dimensions of your current PSU case ?
    Here is the basic
    Dimensions 5.9" x 3.39" x 5.51" of a standard PSU
    Attached Thumbnails Attached Thumbnails [Q] power supply upgrade-psu_standard_size.jpg
  7. Posts : 1,653
    Do you have any idea what graphics card you are thinking about? That would help.
    How many auxiliary PCI-E power connectors will the graphics card need? I expect 2 so you will want to get a PSU that has 2 PCI-E power connector. Usually than means more power - around 500W.
    With 1 graphics card you probably will not need more than 450W on the 12V. Especially if you don't overclock.
    Here are some good ones:
    If only 1 6 pin PCI-E connector is needed, 430W:
    CORSAIR Builder Series CX430 430W ATX12V v2.3 80 PLUS BRONZE Certified Active PFC Power Supply - Newegg.com
    If 1 six pin + 1 6+2 pin:
    430W:
    SeaSonic S12II 430B 430W ATX12V V2.3/EPS12V 80 PLUS BRONZE Certified Active PFC Power Supply - Newegg.com
    520W:
    SeaSonic S12II 520 Bronze 520W ATX12V V2.3 / EPS 12V V2.91 80 PLUS BRONZE Certified Active PFC Power Supply - Newegg.com
    2 6+2 pin:
    450W
    Rosewill CAPSTONE Series CAPSTONE-450 450W Continuous @ 50°C, 80 PLUS GOLD Certified, Single +12V Rail, ATX12V v2.31 / EPS12V v2.92, SLI Ready, CrossFire Ready, Active - PFC Power Supply - Retail - Newegg.com
  8. Posts : 2,606
    Do you have a particular graphics card in mind?
  9. Posts : 26
    Well I was hopeing on this one would be good to stick in my pc
  10. Posts : 1,653
    Any of the PSU I listed above should do. I don't think that card even requires a PCI-E auxiliary power. But you won't be able to play many modern games with it if that is what you are looking for.
