TCell USB 3.0 16Gb flash drive will not show up in my computer
Page 3 of 4 FirstFirst 1234 LastLast
  1. Posts : 306
    windows 7 64bit on both
       #21
    it still shows in My computer, however it is grayed out. i plugged it into all the ports on the mobo IO panel and it changes the drive letter to G: but still grayed out and asks to insert a device into drive G:
    Attached Thumbnails Attached Thumbnails TCell USB 3.0 16Gb flash drive will not show up in my computer-capture.jpg
  2. Posts : 6,830
    Windows 7 Ultimate 32-Bit & Windows 7 Ultimate 64-Bit
       #22
    Can you right click inside computer and choose Format ?
  3. Posts : 306
       #23
    i can, but it still wants me to insert a disk. also, i tried to eject it and it gives me some error along the same lines. i also went to properties and it says 0GB used which i know is wrong because i put the files on and then never got to wipe them off.
    i'm real sorry, i'm not trying to be difficult. this is exactly what it's doing...its so weird!! that's why i keep posting pics...because i'm not BS'ing you LoL
    Attached Thumbnails Attached Thumbnails TCell USB 3.0 16Gb flash drive will not show up in my computer-format-attempt.jpg   TCell USB 3.0 16Gb flash drive will not show up in my computer-eject-attempt.jpg   TCell USB 3.0 16Gb flash drive will not show up in my computer-properties-wrong.jpg
  4. Posts : 6,830
       #24
  5. Posts : 306
       #25
    rrrrgg!! you won't believe this, but neither one of those options were able to recognize the drive was plugged into the computer.
    Attached Thumbnails Attached Thumbnails TCell USB 3.0 16Gb flash drive will not show up in my computer-capture.jpg   TCell USB 3.0 16Gb flash drive will not show up in my computer-capture2.jpg
  6. Posts : 6,830
       #26
    I have sent a PM to Brink to see if he could lend a hand .
  7. Posts : 306
       #27
    thanks! i really appreciate the help. i've just never seen something like this. and i don't want to throw away a great flash drive until i've exhausted all possibilities.
  8. Posts : 72,052
       #28
    Hello Colin,
    This can sometimes happen when the USB flash drive is trying to use a drive letter that has already been used and reserved. As a test, try changing the drive letter of the USB flash drive again, but before you do, check using OPTION TWO below to see what drive letters you have reserved on the PC. Afterwards, change the letter to one not listed.
    It may not have worked before if K had already been used and reserved.
  9. Posts : 7,055
    Windows 7 Home Premium 32 bit
       #29
    In some cases formatting with HP USB Disk Storage Format Tool v 2.2.3 was successful.
    If all else fails, try that.
    You can download it here: Download HP USB Disk Storage Format Tool 2.2.3 Free - Windows-based Format Utility for HP Drive Key or DiskOnKey USB Device - Softpedia
    It is a .exe file.
    Please plug out all external storage devices to avoid selecting a wrong drive.
    Plugin only your problem pen drive.
    Right click on the .exe file and run it as administrator.
    Check that the correct pen drive is selected.
    Format.
    Close the tool, safely remove the drive and plug it in again.
    Let us know how it went.
  10. Posts : 306
       #30
    neither one of the suggestions has worked. sorry guys. i changed the drive letter to Z because i know i've never used that.
    the HP USB Disk Storage Format Tool wouldnt recognize the flash drive was even installed.
    Attached Thumbnails Attached Thumbnails TCell USB 3.0 16Gb flash drive will not show up in my computer-capture.jpg   TCell USB 3.0 16Gb flash drive will not show up in my computer-capture2.jpg   TCell USB 3.0 16Gb flash drive will not show up in my computer-capture3.jpg   TCell USB 3.0 16Gb flash drive will not show up in my computer-capture-no-media.jpg
