Power supply parts for Gaming
  1. Posts : 9
    Windows 7 Home Basic 32 bit
    Hi guys. Can you suggest about what a power supply could be more than enough for a PC? For hardcore gaming. lol thanks
  2. Posts : 12,364
    8 Pro x64
    Corsair AX850W
    A few more details, such as your definition of hardcore gaming. Opinions vary wildly.
    Essentially the rule is Single GPU, 750W. 2 GPU's 850W 3 1000W+
    Never cheap out on a PSU for 'hardcore use'. Always go with a reputable brand.
  3. Posts : 1,045
    Win8/8.1,Win7-U64, Vista U64, uncounted Linux distor's
    The GPU(s) can eat the watts. Two or even three power hungry gpu's, pair of optical drives plus hhd's-ssd's. Overclocked CPU with H2O pump. Add few USB devices and you can see why a 850 or 1000 watt may be the minimum size. 1250 watt PSU's are around.
  4. Posts : 9
    Thanks for the replies. Do you think this will be enough? Omni Electrical the AVR-1000
  5. Posts : 7,683
    Windows 10 Pro
    First, in order to really suggest a power supply to you, we really should know what your system specs are. Otherwise we're just guessing and speculating.
    That said, I'm willing to bet you don't need anything bigger than an 850. And unless you're running multiple high powered GPU's, you definitely don't need a 1200 watt PS.
    And there's obviously some miscommunication here because...
    Omni Electrical the AVR-1000? What kind of Power Supply are you talking about?
  6. Posts : 26,869
    Windows 11 Pro
    The link you provided does not look to be a computer supply. At least not one that I've ever seen. I always recommend Corsair, Seasonic or Antec power supplies. Those are good quality power supplies that will put out the power they claim, where others may not. They also have safety features built in.
  7. Posts : 2,973
    It's rare that a person needs 1000 watts or more. Share, or fill out your system specs as fully as possible and we can narrow things down quite a bit.
  8. Posts : 5,956
    Win 7 Pro x64, Win 10 Pro x64, Linux Light x86
    AVR-1000 looks like some form of UPS ?
  9. Posts : 2,973
    Automatic Voltage Regulator
  10. Posts : 9
    here are the specs. I'm planning to improve my system this june. Maybe you can give me some good suggestions?
    Power supply parts for Gaming Attached Files
