Power supply went out
  1. Posts : 24,479
    Windows 7 Ultimate X64 SP1
    Doug that has to be a serious allergy. Burning circuits are one of the most acrid and stinging of smells.
  2. Posts : 5,915
    Windows 10 Pro X64
       #12
    Must be, the wife opened all the windows and sprayed febreze around. She described it pretty much the way you just said it. And Layback is right, the cats are acting funny. And she just made me put the bad psu out in the garage.
  3. Posts : 7,466
    Dude said:
    Okay, I was reading through the forums earlier, then left (computer still on) to make a store run. I get home about 45 minutes later, put my groceries away then head to my computer. It hit the mouse and keyboard it doesn't respond at first, then it pops up, literally. I suddenly see smoke look right to my tower and see a very light amount of smoke rolling out of the case. I instantly remove the power and take the computer apart. I thought oh #### did my motherboard fry? I check everything after a complete disassembly and see no visible damage or burns any where. I recheck the motherboard again, everything is normal.
    I then carefully look at the power supply, and give it a sniff..yep there is the culprit, a light burnt smell, I don't have the best smell so I missed it at first.
    I then unplug all the modular cables, the pci express 6 pin has a pin that came out when disconnecting, and looks slightly black. Did it take out my card too I wonder.
    I took apart my spare computer, removed the psu and benched it on my rig. Powers right up, no issue. I didn't hook up the video card as the spare PSU isn't powerful enough.
    I bought everything at fry's in Feb, can I take the PSU back there or would I have to go through corsair?
    Do you think my vid card is gone? It has no visible damage, and doesn't smell burnt.
    I just want to cry, please give me any advice on whether I might have lost the card too
    Fry's won't take it back they are jerks when it comes to this you are better off going to Corsair like I did they only give you 15 days
    You Video card isn't gone you got it in time now if everything shut down out of nowhere and that happened cause to be worried most likely the capacitor was old and it just happened that at the time the Videocard was the most power hungry
  4. Posts : 5,915
    Windows 10 Pro X64
       #14
    Thanks Solar, the computer was idle, I came back from the store and tapped the keyboard and mouse to bring the monitor up, then came the smoke. The psu is only four months old
  5. Posts : 25,847
       #15
    Dude do you have your power supply connected directly into the wall outlet?
  6. Posts : 5,915
    Windows 10 Pro X64
       #16
    No, it goes to a surge protector
  7. Posts : 2,686
       #17
    See if Corsair will do cross ship. You give them a credit card and they ship the new one and you have 30 days to return the bad one and if not they charge your card. Saves a lot of time.
    Jim
  8. Posts : 5,915
    Windows 10 Pro X64
       #18
    Thanks Phone Man
  9. Posts : 5,915
    Windows 10 Pro X64
       #19
    I did get the RMA in last night. I was confused on the lot number(google fu said number next to serial number) and it did not work. Googled and found a number. I received an email back stating my RMA was in and gave me a ticket number. It said I will be contacted, so I will then verify I have the right lot number.
  10. Posts : 7,466
       #20
    Should take no more then 2 weeks Corsair is pretty quick with it when it comes to RMA
