MP3 Write Protection USB problem.
  1. Posts : 100
    windows 7 home premium 64bit
    Hello Im confused with this guys answer here, it seems to be the solution to the problem im having.
    Ive insert my sony mp3 player and when I went to delete a folder i got this message:MP3 Write Protection
    Ive understood the instructions upto step c)c. Highlight StorageDevicePolicies, and then create a New DWORD (32-bit) Value named as WriteProtect.
    does he mean just make a new folder , rename it to StorageDevicePolicies? can somone please explain or do a short video tutorial how to do this, I cant seem to find any video tutorials on how to go about,and Im afraid
    incase I ruin the pc function if i make a mistake
    USB flash drive prompts with "Write Protected" message. - Microsoft Community
    thank you.
  2. Posts : 1,711
    Win 7 Pro 64-bit 7601
    Afaik, sony players (as most others) require a specific software to manage them.
    What is the model of your mp3 player?
  3. Posts : 6,285
    Windows 10 Pro X64
    He means to create a new registry key under StorageDevicePolicies key, which will be DWORD value called WriteProtect. It's not really a folder though it looks a bit like one, it's just a sub key under an existing key.
  4. Posts : 100
    this here is the model of my mp3 player:
    Sony launches NWZ-B170 series of Walkman MP3 players
  5. Posts : 100
    hello Ztruker, thats the problem im having I dont have a StorageDevicePolicies key listed.... this is what I have:
    another question is if i try to fix anything in regedit can it ruin my system? is it an important place this regedit?
    Attached Thumbnails Attached Thumbnails MP3 Write Protection USB problem.-seven-forum.jpg
  6. Posts : 1,711
    ok, that device does not need a specific software, it's just drag and drop stuff with explorer.
  7. Posts : 100
    Hi bob.
    thats what I do, drag and drop folders in the mp3 player, But this oen folder I downloaded... says this write protection thing that i cannot simply delete!
  8. Posts : 1,711
    right click and go to properties and untick read only under attributes. I suggest you highlight all the music files you have and do the same thing with them too.
  9. Posts : 100
    read only is unticked under attributes. I have another option which i can click which is"hidden" thats the only box i can tick, as read only is greyed out, cant tick it.
  10. Posts : 1,711
    do you have a button called "unblock" on the files/folders? click on it and it should un-grey the tick box.
