General Battery Question
  1. Posts : 100
    I have purchased a replacement battery for my HP G42 laptop that is not an original HP mainly because its a lot less cheaper. So my question is would this battery have any effect on the other hardware components of my laptop? Btw, I noticed that sometimes it randomly shuts down as if you have physically removed the battery without shutting it down..
  2. Posts : 6,292
    A generic battery will work in your laptop with no adverse effects provided the specifications are an EXACT match to the original OEM battery's specs.
    The important part is: Output voltage.
    After that the important thing is to buy batteries from a seller with good reviews and a good rep. There are just some poorly manufacturered batteries out there.
  3. Posts : 100
    Ok, will check on the info. But the thing is, it shuts down on me when its around 40% below. And when I boot it up again, it asks me if I would want to boot in safe mode or start it normally, I know you understand what im saying, and I know that that msg comes up when you werent able to shut down your cpmputer properly, and because of that I am a bit worried that it may affect my laptop in general..
  4. Posts : 6,292
    Yes, there is something wrong with that battery. The laptop should not just shut off without the 10% warning first. You are putting the PC at risk until you solve this.
  5. Posts : 11,424
    Windows 7 Ultimate 64
    Look in the bios and or lappy manual, many lappys have a feature for calibrating the battery and you want to perform this function so the system can identify the condition and capacity of it's new battery.
  6. Posts : 100
    I see. Ok, I will try this and give a feedback. Btw, I dont hace access to my manuals and wont have anytime soon, so can you at least point me to where to look for the calibration in the bios? I hacr an HP G42-476TX.
  7. Posts : 6,243
    Hi synth, Try here http://h20000.www2.hp.com/bizsupport...riesId=4346229 for the manuals and if you need the drivers at any time go here HP G42-400 Notebook PC series - Download drivers and software - HP Business Support Center :)
  8. Posts : 17,322
    Win 10 Pro x64
    Here you go,
    HP Notebook PCs - Testing and Calibrating the Battery (Windows 7) - c00821536 - HP Business Support Center
    Attached Thumbnails Attached Thumbnails General Battery Question-battery.jpg
  9. Posts : 100
    @derekimo
    Thanks man, but in my bios, battery test does not show up and my battery percentege is at 75%. And when I try using HP Support Assistant, it does check it but it only gives a blank screen after the test..
    Is it because this battery is NOT an original HP?
  10. Posts : 100
    Ok, so anyways, here's a photo of the two batteries:
    Top battery is the replacement non-HP battery I bought recently.
    Bottom battery is the Original HP that came with this laptop.
    If you can zoom in, you can see the voltage and capacity.
    Replacement battery specs: 10.8V, 5200mAh
    Original HP Battery specs: 10.8V, 4200mAh
    Basically the replacement battery should be able to hold more charge than the original one since it has more mAh right? Anyways, I ran the HP Support Assistant Battery test on the original HP battery that has problems and this is what i got:
    So, what do you guys think? And is there any other way I can calibrate this replacement battery?
