Device driver installation will not see the hardware
Page 4 of 7 FirstFirst ... 23456 ... LastLast
  1. Posts : 6,830
    Windows 7 Ultimate 32-Bit & Windows 7 Ultimate 64-Bit
       #31
    Can you open a web page
  2. Posts : 51
    Windows 7 Pro 64 bit
       #32
    No, I get "You're not connected to a network". Norton Internet security stating no connection either. The icon in the lower right has a red X.
  3. Posts : 6,830
       #33
    First thing id remove NIS completely .
    Click here ftp://ftp.symantec.com/public/englis...moval_Tool.exe
    Right click and select
  4. Posts : 51
       #34
    Why do you say remove NIS? It was just an example of one of the programs that cannot access the internet during startup. Another is Outlook.
  5. Posts : 51
       #35
    Out of curiosity I entered: ipconfig /all at the cmd prompt, and I got back
    Host Name . . . . . . . . . . .: TJ-PC
    Primary Dns Suffix . . . . . . :
    Node Type . . . . . . . . . . . : Hybrid
    IP Routing Enabled. . . . . . : No
    WINS Proxy Enabled. . . . . : No
    Nothing else, and from what I've seen in the past there is supposed to be a lot more.
  6. Posts : 51
       #36
    During first restart during Norton removal process I went into the Intel(R) Boot Agent and found that at this level the PWA Number and the MAC Address of the CT Adapter card I bought yesterday is correctly identified and matches the sticker on the adapter. JUst not showing up in the "ipconfig /all" results.
    Related note: Windows firewall is not working either.
  7. Posts : 51
       #37
    I downloaded that Norton app at 5:33 this am. It is now 8:33. Took 3 hours to get that thing to run.
    Ran it twice, restarting each time. It did suggest at the end if not installing a Norton product to turn on Windows Firewall.
    I got: There was an error opening Windows Firewall with Advanced Security Snap-in. The WFwASS failed to load. Restart the Windows Firewall Service on the computer that you are managing. Error code 0x6D9
    No surprise there as it has not worked since the whole internet access thing began.
    Still not connecting. Same ipconfig info as recently posted. Still a blank window when I open Change Adapter Settings. Still a red X on the network icon in the lower right.
  8. Posts : 51
       #38
    Went into Services and checked to see if Win Firewall set to automatic. It is. I get a 1068 if I try to start it.
  9. Posts : 6,830
       #39
    On a PC that has Internet download the tool below and use a USB drive to transfer it to the PC that can't go on the Internet
    Farbar Service Scanner
    Click here Farbar Service Scanner to DOWNLOAD
    Place the file onto your desktop
    Right click on FSS.exe select
    Place a check mark next to the following options
    • ⬜ Internet Services
    • ⬜ Windows Firewall
    • ⬜ System Restore
    • ⬜ Security Center
    • ⬜ Windows Update
    • ⬜ Windows Defender
    Press the Scan button
    Farbar Service Scanner will create a log, called FSS.txt, on the Desktop. Place the fss.txt file inside the usb drive . Upload the FSS.txt with your reply
  10. Posts : 51
       #40
    FSS done. Here it is...
    Device driver installation will not see the hardware Attached Files
