Hello,
I have installed vista 32 bit on a partitioned drive of my vaio laptop which cam with windows 7 64 bit.
I have numbed myself to some of the issues i have with seven, but i can not use it for my music (WMP12 stinks, library issues).
I have vista up and running, but when the intel...
Hello This is CrazyKilla
I am here with another porblem,
I recently got a new custom pc, i have a 300Gb 32bit hard drive, stupid me forgot to save my files from the 32 bit hard drive, onto a usb, now i have a 64bit system, and a 64bit hard drive, i want to get my files back from the 32bit HD...
I did ask a question about this some time ago and discovered that there was no easy way to do it (I'd thought to use Macrium Reflect).
I recently saw that there is now a facility within Macrium Reflect - Redeploy - that reads as if it could be used.
Does anyone know whether this would be...
It has been said that the 32bit IE9 is a lot faster than it's 64bit sibling. But the installation of the 32bit version on a 64bit system is a bit confusing. This article helps.
More...
HI, I have a 64bit win7 system, and I also have a sofeware that can work well in a 32 bit system, But it can not be setup in a 64 bit system,How can i make that work in my 64 bit system?
I have update the windows to latest.
Thanks very much.
