Have enough power/wattage?
  1. Posts : 349
    MS Windows 7 Professional 64-bit SP1
    Alright, I have 6 fans in my computer that are led and I plan on changing them.
    At the moment I have an i5 2400, SSD, HDD, GeForce GTX 550 Ti, 8gb DDR3 RAM, DVD drive, 4 120mm blue led fans, and 2 140mm led fans. This is all being run by a 630W PSU.
    Now the reason I'm asking if I have enough power is because I plan on switching the 6 led case fans to regular non-led fans, adding a fan controller, and getting the NZXT RGB HUE.
    Do you think the 630W PSU will suffice or would I need something better?
    Also, what are some good 120mm and 140mm fans that aren't too expensive? Hopefully black or white fans/fan blades. One or the other, or both.. doesn't matter. I just don't want something that's not going to match my case.
  2. Posts : 9,606
    Check out Extreme PS Calculator
    eXtreme Power Supply Calculator
    You can find all makes & models of fans at www.NewEgg.com also all different price ranges
  3. Posts : 349
    I've done both, but that doesn't seem right for the calculator. 371W for everything I mentioned?
    Also, the fans aren't too easy to pick out. I want something with decent airflow and quiet.
  4. Posts : 184
    UnknownReverent said:
    ...I have 6 fans in my computer that are led and I plan on changing them. At the moment I have an i5 2400, SSD, HDD, GeForce GTX 550 Ti, 8gb DDR3 RAM, DVD drive, 4 120mm blue led fans, and 2 140mm led fans. This is all being run by a 630W PSU...
    6 case fans is too many for 1 desktop computer. They're just fighting each other, giving less air flow through the case than two, 1 inlet & 1 outlet. 2 will make a lot less noise than 6. Power is not an issue, each fan probably draws 0.25A.
  5. Posts : 349
    I have two front, two top, one bottom, and one in the back. At the moment, there's no issue with noise with what I have. Whether or not having six fans wasn't my question though. No one has seemed to answer me directly.
