problem with my PC power supply
  1. Posts : 27
    windows 7 64bit gaming EDITION
    my specs
    mobo:P8B75-MLX
    P8B75-M LX - Motherboards - ASUS
    ram:8gb
    graphics card:gtx 660 Twin Frozr 2gb
    and my PSU:Cooler Master EX2 525watt
    Cooler Master: Extreme 2 525
    i just bought some 3 weeks
    and now turn on my pc
    and
    no power or
    damage
    but my old psu 230watt works fine
    or psu 525watt too much power for gtx 660
    can cause damage
    or my motherboard cannot handle
    sorry for my bad english
  2. Posts : 11,424
    Windows 7 Ultimate 64
    AIMAN SNK,
    Welcome to SF and the answer to your questions is no, this PSU is likely bad but if it is or was performing well and connected properly then more power is never a danger as the components only draw the power they need.
  3. Posts : 25,847
    As linnemeyerhere has stated. You can't have to much power supply.
    If you computer demands lets say 300W a 1000 W power supply will only put out 300W.
    A quality power supply for your system I would recommend a Corsair or Seasonic in the 650W range.
    Your video card requires a 500W or higher.
  4. Posts : 24,479
    Windows 7 Ultimate X64 SP1
    If you only bought it 3 weeks ago take it back to the store for a new one. If you built it, return the PSU.
    Make sure all cables are connected and there is power coming from the wall outlet.
  5. Posts : 11,424
    Did you by accident flip the power switch on the PSU? Don't laugh it's happened to me.....
  6. Posts : 27
    mmmm first time i bought i see is off
    now switch to ON
    but that is first i bought and after that i dont touch anymore
    can I ask a question
    safe if I switch to kernel mode
    on MSI AFTERBURNER
    or do you has a guide about setting on msi afterburn
  7. Posts : 13,576
    So is everything ok now ?
  8. Posts : 11,424
    now switch to ON
    on MSI AFTERBURNER
    I would open a new thread regarding the Afterburner and if the PSU is working then mark this thread solved and good job !
  9. Posts : 24,479
    Yes for After Burner issues post a new thread here: Graphic Cards - Windows 7 Help Forums
  10. Posts : 27
    ok thank you for help
