CPU running 100% - Screens posted - Help Appreciated
I am having a problem with my CPU getting used up 100%. No process is showing to be causing it but it usually just sits at 100%. I have gone through all the steps to make sure it isnt a virus, and it is not, and have disable all un needed startup services and programs.
The problem does not happen is Safe mode, and i was not able to do a fresh install, because it got hung up at the gathering files part.
I disabled my high definition audio and that is not the problem either.
http://img255.imageshack.us/img255/7...monitorqn7.jpg
