Hey guys I was playing DOTA 2 and my computer blue screened.
Now the thing is that strange is that dota 2 is not a very intensive game.... Not at all. I run Day-Z fine without any blue screens or anything. And that game is much more taxing on the CPU than Dota is.
I got a blue screen in the...
I had a better card in the PC and was running the AMD catalyst drivers.
I took that card out and put in the x1300.
Several times noticed some weird effects.
Then today I powered down cause it was pink, and it refused to turn on the screen.
So I let it sit and it is working again.
I did not...
And I'm back again giving you another annoying dilemma to help me with.
Okay, the problems are on my main pc. The specs are below:
Windows 7 Ult. 64bit
Gigabyte 880GA-UD3H
AMD Phenom II X6 1100T
4GB DDR3 PNY RAM
500GB Seagate HDD
Dynex 400 Watt Power Supply
I use 2 screens with my system. I also, use media center a lot. Usually, when you put media center in full screen mode, you can only use the one monitor. Now sometimes I can use both screens at the same time, even though media center is in full screen. How can I make that permanent? I'm actually...
