Thank's for commenting i'll give it a try.
Nope the long time charging overnight didn't help I think I need to get e new batter y then .
Last time I had to buy a battery I got it from here. The price was pretty good. You have to enter your model into the search fiels to find a match - if any available.
HP 12 cell Battery ev089aa Hstnn-db02 for HP DV6000 DV2000
I don't know whether a 12 cell will last longer. But it gives you much longer running time on one charge than the 6 cell.
Somehow The battery started charging, this happened before I think it's because I haven't used it in a while and it was completely cold hopefully it last longer and I can use to more and not buy another battery and mine is a 9 cell model witch work's know thank's for your help everyone !
