There is a problem with your battery
Page 2 of 2 FirstFirst 12
  1. Posts : 108
    Windows 7 Ultimate x86
    archer said:
    Yes, please keep sleep time.
    ok...but it automatically sleep after given time ?
    Pher eh ditte hoye time to baad band ho jayoga ? Mai kinna time rakha ?
  2. Posts : 7,379
    Windows 7 ultimate x64
       #12
    Yes, it will sleep after the time you select. You can select any time with which you are comfortable with.
  3. Posts : 108
    if i select never,then ?
  4. Posts : 7,379
       #14
    If you select "Never". Your system will not sleep at all. Display will be always on.
  5. Posts : 108
       #15
    ok...i asked it because in the battery report there were errors about sleep time.
    I'm speaking in english because this is is english forum & see the rules,if u want to speak in our language,pm me
  6. Posts : 108
       #16
    new energy report with lots of errors & warnings.this time re-installed windows & no sign of replace battery error,but in report battery life decreased.i don't think this is because of battery dying.i think my processor @ high usage & lots of other errors & warnings causing this,plz look @ it >>
    There is a problem with your battery Attached Files
  7. Posts : 7,379
       #17
    OK, This time results are
    Design Capacity 57200
    Last Full Charge 35299
    So, we can be assured that the battery is not the issue. Run Malware bytes and CCleaner to scan and clean the PC with any errors. Run SFC /SCNNOW.
    Keep us posted dude.
  8. Posts : 24,479
    Windows 7 Ultimate X64 SP1
       #18
    Archer, what do the number mean?
  9. Posts : 7,379
       #19
    Hey Britton..numbers mean..how much the battery should hold and how much it is holding....charge
  10. Posts : 108
       #20
    Hi..i'll try it..btw i tried malwarebytes before.but it's not good & also ccleaner,but that's also not very useful.i'm using only windows internal programs for cleaning & i have Kaspersky internet security 2013 :)
