Yes, it will sleep after the time you select. You can select any time with which you are comfortable with.
new energy report with lots of errors & warnings.this time re-installed windows & no sign of replace battery error,but in report battery life decreased.i don't think this is because of battery dying.i think my processor @ high usage & lots of other errors & warnings causing this,plz look @ it >>
OK, This time results are
Design Capacity 57200
Last Full Charge 35299
So, we can be assured that the battery is not the issue. Run Malware bytes and CCleaner to scan and clean the PC with any errors. Run SFC /SCNNOW.
Keep us posted dude.
Hey Britton..numbers mean..how much the battery should hold and how much it is holding....charge
Hi..i'll try it..btw i tried malwarebytes before.but it's not good & also ccleaner,but that's also not very useful.i'm using only windows internal programs for cleaning & i have Kaspersky internet security 2013 :)
