Help please selecting a Win7 laptop replacement battery
  1. Posts : 10
    Windows 7 Pro 64 bit
    Hello,
    My battery is dying. I've done a few things in an attempt to fix the "consider replacing your battery" warning and none of them has worked. I run my laptop in high performance mode (for audio recording) and I have no problem thinking it might just be dying.
    So I need to replace it. I have NO IDEA what to look for in a replacement battery. I have done searches and found numbers similar to what I have but none that match exactly. Specifically, I have not found any that are 5600mAh, only smaller numbers.
    So I would dearly appreciate a little help. Here's my computer via Sandra report:
    Model : Clevo W150HNM/W170HN HuronRiver System
    Serial Number : System Ser**********
    Chassis : Clevo Laptop
    Mainboard : Clevo W150HNM/W170HN
    BIOS : Phoenix (OEM) HR_2.1.0.128 X64 10/07/2011
    Intel vPro : 7.00.10.1203
    Total Memory : 7.92GB DDR3 SO-DIMM
    And here's what the battery says on it:
    Li-Ion Battery Pack
    Model C4500BAT-6 (SIMPLO)
    11.1V
    5600mAh
    62.16Wh
    6-87-E412S-4D7
    Incidentally, there is a sticker on it that says FEB-'12. I assume that means when the battery was made because I bought the laptop in April of 2012 and this is the original battery.
    I find close matches when I search for a replacement but they are 4400mAh or some such. I know some numbers are more important than others but I don't know which is which.
    Thanks for any help!
    Tim
  2. Posts : 18,415
    windows 7 home 64bit
  3. Posts : 10
    Thank you maxie! My question now is, just for learning, what's the difference between my current battery at 5600mAh and the replacement at 4400mAh?
  4. Posts : 18,415
    mAh stands for milli Ampere-Hour WH stands for watt-hours. Both are a measure of the total amount of energy stored in a battery. So, the higher the better if you want the laptop to work for a long time on the battery's power. The important thing though is the voltage. You can replace a battery of low mAH or WH with one of higher rating, but if the voltages don't match, at best your laptop will not power on, and at worst, it will smoke and burn when you power it on.
  5. Posts : 4,751
